Ourhouse75706
Mar 13, 2018Aspirant
Nighthawk M1 No Wifi
My M1 is showing that the wifi is enabled but it does not broadcast to any devices. I have factory reset it and nothing changes. What else is there to do?
- UK-basedLuminary
The M1 is designed primarily as a battery-powered mobile hotspot, although some of us are successfully using it as a static 24/7 household router. So the default factory settings aim to minimise the battery drain. For example, the WiFi will sleep after a period of time, probably requiring the Power button to be tapped once to wake it up again. Also, I think the WiFi range is set to "Short". So those are two things to check/change in the Settings > Setup > Wireless section of the browser-based interface. I'm using my M1 without a battery so I've disabled the "WiFi Standby" and have set the WiFi range to "Long". The range is still rather limited but that's to be expected in a relatively small mobile hotspot. If needs be, you can extend its range using Ethernet-connected access points.
I can't think of any other reason why your WiFi devices aren't seeing the M1. If no one else comes up with any solutions, I'd contact your supplier.
- Ourhouse75706AspirantThank you both for your help. I did have the WiFi sleep setting disabled and I remember messing with the long short setting and nothing fixed it. I ended up exchanging it for another one and have not had any issues as of yet. This post can be closed or deleted if needed.
Thank you for your help.
- JasonNNETGEAR Employee Retired
Hi Ourhouse75706,
I wanted to check in and see if UK-based's steps helped fix your issue. If not then I will procced to give you further assistance.
Please let me know. :]
- Jason N
