Rickrock
Apr 29, 2020Follower
Nighthawk M1 not supported by netgear Mobile App??
I'm trying to connect my Nighthawk to the mobile app but the message on the mobile app says
Sorry, this mobile Router is not supported by the netgear mobile app.
I've re installed the app, but still no go
Probably because the message is correct.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
- minskuAspirant
michaelkenward Op was not asking about the Nighthawk app but the Mobile app that is supposed to work with M1. Having the very same issue here.
So why post in the section for the Nighthawk app if that wasn't what they meant?
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
- GoodandBaddogAspirantI am getting same message all of a sudden?
Any resolve?- schumakuGuru - Experienced User
As above - stick wih the Mobile Routers, Hotspots & Modems section please.
- Ksa3344ApprenticeIt didn't work with me when i changed its IP from 192.168.1.1to 192.168.10.1 .
It works again when i returned it to its default IP , so make sure you haven't changed it and it should work fine .
