eip618
May 05, 2017Aspirant
Nighthawk M1 rebooting randomly
I got the Nighthawk yesterday. It is randomly rebooting itself even though it is connected to a consistent, correct voltage power source and will reboot whenever it feels like it.
I assume this is a software issue.
- eip618Aspirantnot really. but it varies. I can have an hour of operation, then a reboot, then twenty minutes then a reboot. It doesn't seem related to any variables like temperature or charge state, or network load.
- eip618Aspirantupdate: seems to only happen when the modem is actively charging
- eip618Aspirantupdate: only when the modem is tethering via USB
- poiterAspirant
Hi, I have picked up a Nighthawk M1 today via Telstra and found that the device is frequently rebooting making the device almost useless.
The device reboots whether plugged into AC, operating off fully charged battery or plugged in PC via USB.
The only changes to setup i have done are to disable the wifi standby mode and change the option for WIFI range to long.
Every time it reboots, it will take several minutes to restart and reconnect devices. The frequency of reboots so far is quite short, several minutes and multiple reboots within an hour.
Very disappointing as I was hoping to would repalce my poor ADSL connection. I think this device will be going back to the Telstra store.
Any solutions to this?
Hardware version 1.0
PRI version 02.15
Firmware & Bootloader Version NTG9X50C_10.16.04.04
GUI Version MR1HDATA_04.01.05.02
Firmware build date 2017/07/13
- BRocheAspirant
I'm on my 3rd Nighthawk from Telstra. 1st one lasted a week before it wouldn't turn on anymore (took 2 weeks to replace) 2nd one went into a reboot loop that you couldn't get out of and now my 3rd unit is doing frequent reboots under load via ethernet.
I have done a factory reset, and have latest firmware as of 25/10/2017.
I have a Xbox connected via ethernet (for netflix, youtube and games) and laptop via wifi. If watching netflix then try and do intensive network load on laptop, Nightwawk reboots. If I try and update the XBox (large download) Nighthawk reboots. Connect laptop via ethernet and try a speedtest, nighthawk reboots. So far I'm extreamly dissapointed with this device, I would hate to see 20 devices connected to it. I looks like the ethernet port just can't handle the load??
Also hoping this would replace my crappy ADSL+ 3Mbps connection :(
- poiterAspirant
Update:
First unit was evaluated by my local Telstra store and found to be faulty.
They had intended to observe for themselves and then do a factory reset but were met with reboots and did not proceed further.
Fortunately, Telstra made the choice to replace with a new unit. I would not have expected less as the first unit malfunctioned immediately and I only had it 2 days.
I have not sighted any unexpected reboots in the new unit and all seems to be functioning perfectly. Fingers crossed.
It is a great device when working properly, but I did some searching online and given the number of reports of this unit rebooting/restarting, there must be a persistent fault/issue with the build quality of the units.
- Ray2017Tutor
My nighthawk Mr1100 keeps rebooting randomly as others have found .
I have noticed (I move address often) it is much worse in a strong signal area.
In a very strong area it could be constant making it unusable, in a weak area 15 munutes to several hours before a re boot.
Please get the technicians onto this.
