Pt1936
May 25, 2023Tutor
Nighthawk m1 shuts down
Using in a motorhome in storage off 5v usb supply. After about 4 days unit shuts down. Only way to restart is to remove battery then attach to power. Unit only a few months old. Battery is fully charged.
Pt1936 wrote:
Is that also the case for constant dc power? It’s in a motorhome, plugged into a usb power supply. I’ll try it without the battery.
The power supply converts to DC power anyway.
