Serendipite
Dec 05, 2021Follower
Nighthawk M2 disabled
My nighthawk m2 says WIFI Network is disabled but when I try to enable the screen comes up with WIFI Name Disabled and WIFI Password disabled and just continues to try and detect service...I am totally not tech savvy...can anyone help please!!!
- IYGEALAspirant
I have this exact problem
- JohnPengNETGEAR Expert
Did factory reset helping with your issue? What is the SKU name of your device and what is the FW version on it?
Thanks
John
- IYGEALAspirantIn my case factory reset hasn't helped. Model is AUS version (M21001TAUS), FW is 24.10.17.10. I made a detailed post on the other thread with 95 replies.
IYGEAL wrote:
In my case factory reset hasn't helped. Model is AUS version (M21001TAUS), FW is 24.10.17.10. I made a detailed post on the other thread with 95 replies.Can you log in to WebUI and enable ethernet offloading and do a FW upgrade check? There is a newer version available for your device.
FW: 10.19.03.00 and PRI 05.02
Thanks
John
- IYGEALAspirant
Serendipite wrote:
My nighthawk m2 says WIFI Network is disabled but when I try to enable the screen comes up with WIFI Name Disabled and WIFI Password disabled and just continues to try and detect service...I am totally not tech savvy...can anyone help please!!!Were you able to fix this problem?
Mine is still like this and there seems to be no hope of progress.- IYGEALAspirant
Really frustrated that this device can't be updated now, and the problem persists.
