Thosmas's avatar
Thosmas
Nighthawk M2100
I have the above device which won’t start up, initially it flashes blue gets to 2 dots on the screen then flashes red every 5 seconds!
it won’t go any further!
any help please!
  • plemans's avatar
    1. did you try a factory reset?
    2. or removing the battery?
    3. is your battery charged or using an approved charger? (i've seen reports that a 2.4amp charger will run it without a battery)
    4. is it new? or how old is it?
    • Transfluxor's avatar
      Transfluxor
      Apprentice
      How to do a reset if the router does not boot? It doesn't matter if it has a SIM in it or not, whether it has a battery or not, it just won't boot. Instead of a bunch of useless questions, it would be better to post the firmware, the router is switched to bootloader mode.
      • Thosmas's avatar
        Thosmas
        Hi
        thx for response
        i can’t get firmware if it doesn’t boot
        how do I get out of boot loader mode?
    • Thosmas's avatar
      Thosmas
      Hi
      thx for response
      yes I’ve pressed the reset and held button many times.
      yes I’ve tried without battery
      im using the charger from an M1 router
      it two yrs old
