waterwheelfarm's avatar
Apr 05, 2024
Nighthawk M6 Pro MR6500 hot spot OEM power adapter
I purchased a refurbed unit through amazon and it did not come with a netgear power adapter & cord. I want to run this unit without the battery, but when I removed it, received the message:
Use the supplied power adapter when operating without the battery
I headed to my local AT&T store and we tried different power adapters to come up with the volts/amps needed (20w/5v/3a). I know I can buy one, but thought I'd reach out to Netgear to see if I could get a part number and try to order an OEM one.
Well, I have a 90 warranty, yet customer support was completely unhelpful! They originally said they would ship another power adapter, however the powers that be said no, not unless I can give them the correct part number, even though they have my model number and serial number. Grr....
Could anyone provide me with the correct part numbers for the power adapter & cord (should be printed on the side of the cord) for this unit?
  • JT240Z's avatar
    JT240Z
    Apr 06, 2024
    The one you found should work at 5V/3A/20W.  The voltage is critical, but the amperage and wattage can be anything above what you stated.  A 4-amp 30 or 40W adapter would be better.  I don't have mine in front of me but when I get home, I'll see if it has a specific rating.
  • Unfortunately Netgear has chosen to not sell the power adapter by itself.  No way to purchase the "OEM Netgear" power adapter.
    • waterwheelfarm's avatar
      waterwheelfarm
      Well that's a shame. I wish they would at least confirm what I should get.
      Does anyone know the correct volts/amps/watts I should use with this to run without the battery?
      • JT240Z's avatar
        JT240Z
        Luminary
