ktsaved
Mar 18, 2023Initiate
Nighthawk M6 Pro VPN Traffic Disconnects
Nighthawk M6 Pro, AT&T.
Creating VPN connection out to remote site.
VPN connects and traffic flows initially.
After a few minutes VPN traffic stops even though the VPN shows it is still up.
After some time, the traffic may start flowing again for a few minutes.
This cycle keeps repeating.
Can ping out to the remote site, the remote site receives and sends replies but the replies do not get back through the M6 to the sending device.
During this time, pings succeed to the public IP address of the remote site and to other sites on the internet.
Internet communication is fine but the VPN traffic itself doesn't make it back through the M6.
VPN Passthrough is enabled.
Have tried using DMZ and setting port forwarding rules manuall.
No settings change makes any difference.
- WillowCTXAspirant
I have this issue as well. been going on a few months,
- ktsavedInitiate
Solution:
After getting a static IP address assigned to the service the VPN will now stay connected.
It's actually a public IP that is routable on the internet.
The dynamic IPs are private addresses and they are doing something in their network that is interfering with the VPN.
Service in use is AT&T.
Very hard to actually get a static IP from AT&T, not because they don't sell them, but because the call center people can't do it, they send people to the stores to get one, the stores can't do it and a lot of those people don't even know what one is. Very hard to get to the right department.
After hours on the phone, they gave me the number of the BMIOD department.
This department requires a PIN to connect to anyone, and after connecting they will ask you the for the PIN.
I finally convinced one call center worker that I needed a PIN and they gave me a generic PIN.
The man I spoke with then asked for a PIN and wondered how I was able to get through to him.
I started explaining the situation and he stepped in to help me around the normal procedure. He put in a request to the department the assigns the static IPs and I had one on the account in a few hours.
There is a huge gap between the telecom departments. They make it very difficult to buy services from them.
Their "Advanced Technical Support" department is in name only. It's just another line to a call center where they don't know much at all.
- idck_deTutor
Thanks for sharing that. Majority does not pay attention to these.
- justinwelchAspirant
Did you have to do anything on the M6 Pro when configuring the static IP address? I had a static IP address assigned to me by Verizon but the M6 Pro never "took it". With the previous Cisco device I was using, I had to manually enter/assign the ISP static IP address. I don't see a way to be able to do that with the M6 Pro.
Thanks!
- JohnPengNETGEAR Expert
Thanks!
For your static IP case, you can try to enable IP Passthrough on M6 Pro. Then the static IP can be passed to your Ethernet client.
Please check whether this works for you.
Thanks
John
Please contact AT&T to see whether they have VPN enabled data service. Most carriers provide such service with extra costs for business customers. This is not device issue.
Thanks
