brittb92
Jun 06, 2025Follower
Nighthawk M7 Pro Hotspot Wifi range stuck on "Long"???
Hello! This is a recent issue that has started within the last couple of days and I'm not sure how to fix it... Usually when my hotspot resets, it automatically changes it to the "long" wifi range option. I don't like this because it makes my connection issues bad, so I set it back to "standard" every time.
Now, my hotspot is set to "long" range and I am unable to change it?? The page is grayed out and while I see the option for "standard," I can no longer tap on it.
Does anyone have an easy solution for this?? Any help would be greatly appreciated!! (yes I have tried to turn it off and back on again)
No RepliesBe the first to reply
