reading_na
Mar 07, 2023Follower
Nighthawk MR1100-1TLAUS Firmware Upgrade
Good afternoon ,
I just did a factory reset on my Nighthawk MR1100-1TLAUS.
I am trying to upgrade the firmware to the lastest version
( MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04.secc.spk )
I use the check for upgrades it doesn't return any updates and I have also down loaded the above mentioned file and it also fails the manual update process with an error ( Invalid Update File: Error Code 16 )
Would any one be able to point me in the right direction to solve this issue.
Thanks in advance.
Nigel
- JohnPengNETGEAR Expert
Please check the FW version on your device. Your device may be on the latest release already.
Latest release:
FW:12.06.08.00; PRI 05.05.
Thanks
- LaoskidoAspirantIs there a miss listed source for this Mr1100 1tlaus version on the netgear GPL release ?
Currently, there are 2 files, one for pri 04.04 and other for 05.05
However, both are identical , point to 1 file of downloaded.
Furthermore, the releases on GPL is 12.06.02.00, this is way different than what stated for pri 05.05
Could you please check sir
- petehelmAspirant
Hi
I have exactly the same problem with firmware upgrades on my MR1100-1TLAUS. MR1100-1TLAUS_04.01.73.00
build 9TG9X50C_12.06.02.00
The check for updates fails to retrieve any later revisions of the firmware.
When I try and manually install Firmware MR1100-1TLAUS_23113199_NTG9x50C_10.25.01.01_00_TELSTRA_03.22.secc I get the message Invalid update file error code 16.
I Also tried Version 12.06.05.00 where I receive a message - invalid update file. this update is not intended for this product. (MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc)
The same with Firmware Version 12.06.11.00 (MR1100-100EUS_23113509_NTG9x50C_12.06.11.00_00_Generic_10.03.secc)
Has anyone resolved this issue. I am sure there are important security patches in the later firmware versionsThanks
Peter
