Knot2Shabby
Nov 06, 2017Aspirant
Nighthawk password reset from factory to one I want to use
Just got home with my new Nighthawk MR100 Mobile Router. Salesrep at AT&T wasn't helpful and I'm having difficulty setting the password from the original "out-of-the-box" to a password I can remember.
I downloaded the mobile app "M Netgear Mobile" at the AT&T store and thought I had my new password set in the Nighthawk before I left, but got home and it's still the bizzare password that it came with. Tried again 5 times using the app to reset the password using the app, but nothing works.
Any tips?
- JamesGLMaster
Hi Knot2Shabby,
Are your referring to the WiFi password of the router? If yes, please check page 51 of the user manual.
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf
- Knot2ShabbyAspirant
Thanks for the link, I'll check it out. My Nighthawk only came with a single page "manual" not having the link you provided.
