dnogwat
May 03, 2018Aspirant
No LTE Advanced connection on AC790
So, I have a problem with the netgear ac790. I reach very low download speeds around 30-50 mbit/sec. According to the specifications of this device it supports category 6 LTE, which means download speeds up to 300mbit/sec.
If i place the same simcard in my iPhone SE, which also supports cat. 6 LTE, I reach download speeds around 150mbit/sec.
How come the download speed is so low on this device? I have tried changing the wifi range from medium to long and i have tried connecting the aircard via usb to my laptop, but both didnt improve the download speed.
How can i fix this?? Is it a device problem? Or is the signal poor? Will buying a MIMO antenna improve the speed? And what about the netgear cradle D112A? Or do these two devices only improve the wifi signal, instead of the LTE reception?
- JasonNNETGEAR Employee Retired
Hi dnogwat,
Thank you for posting to the community with your issue. I will be looking into this situation for a resolution.
Which provider model is your AC790?
Is your device up-to-date to the most current firmware?
Have you performed a factory reset?
Please let me know. :]
- Jason N
- dnogwatAspirant
Hi Jason,
Thank you for willing to look into my problem.
I live in the Netherlands. They dont sell provider locked aircards here. The provider of my simcard is T-Mobile NL.
Yes, my device is up-to-date with the most current firmware.
Yes, I have done several factory resets.
David
- dnogwatAspirant
So, did you find a resolution?
