nurber
Jun 12, 2017Aspirant
Nominal voltage range of LB1110 ?
Hi. I'm installing this device in an RV and would like to power the device with DC directly. The included AC adapter is rated 12V @ 1A. Can this device be wired directly to an automotive DC supply which has nominal of 12.6-14V ? What size fuse is recommended ? FWIW, this item does not appear in the list of models above.
Thank you, Nurber
- nurberAspirantSorry, correct model is LB1120. Don't see any way to edit original message - DarrenMSr. NETGEAR ModeratorHello nurber We recommend using AC power. No way you can find a converter for this? DarrenM - nurberAspirant
 DarrenM wrote:Hello nurber We recommend using AC power. No way you can find a converter for this? DarrenM Hi DarrenM. How can you recommend using AC power when the device runs on DC ? My question is about nominal voltage range. The LB1120 is inherently a DC product and as the included AC power supply outputs 12V DC you should be able to provide me a published or non-published "Operating voltage range" of something like 10.5-14.5VDC. Appreciatvely, Nurber
