Vispen74
Jul 03, 2017Tutor
Port Forward problems DC112A
No matter what port I forward in the settings, I will always be forward to some Netgear AirCard error page when trying to reach my server from outside. I connect to internet with a AirCard AC785 that...
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Have you setup the port forwarding on the Aircard interface as well as the dock itself?
DarrenM
Vispen74
Jul 06, 2017Tutor
No, only in the dock. Do I need to set the port forwarding in the aircard as well? Should I point to the usb adress (.4) or the end equipments lan adress when forwarding ports in the aircard?
As a temporarily solution I set the Aircard in bridged mode to make it work.
- DarrenMJul 10, 2017Sr. NETGEAR Moderator
Hello Vispen74
That could be the issue was both the dock and air card routing was causing a conflict so you will have to bridge one or set the dock as a AP.
DarrenM
