jbowlingknoxNG's avatar
Apr 29, 2018
Port Forwarding on Nighthawk M1
Has anyone had luck with port forwarding on ATT wireless network.  I have a panasonic security camera that I would like to monitor when not at home.  I have done this before with ATT DSL but am not having luck with the wireless network.   The camera uses a dynamic DNS which I am pretty certain is setup correctly.
I am first confused by the IP addresses that are being reported.  The configuration page for the mobile router reports a 10.126.XXX.XXX address.  When I run an IP check the address that is returned is 107.77.XXX.XXX.  When I ping my specifc address from the dynamic DNS it reports a third address 107.77.XXX.XXX (first and second set of XXX are different).  I am not certain why these are all different but I think it has something to do with ATT wireless network (I have read about double NAT).
Regardless of the address when I work with the port forwarding menu of the mobile router I am not having luck.  Is there a specific port number that I should be using.  I have got this to work using ports in the 50000 range in the past but nothing I am doing now seems to work?
Any thoughts or suggestions would be appreciated.
Thanks
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi jbowlingknoxNG,
    Can you please check with your ISP and see if their network supports port forwarding for your device?
    Please let me know. :]
    - Jason N
    • jbowlingknoxNG's avatar
      jbowlingknoxNG
      The ISP is ATT Mobile.  I have contacted tech support twice and was told both times that they do.  At the second contact I inquired if the IP was public at the request of Netgear support and ATT said that the address of the mobile router was indeed public.  When I pressed ATT and port forwarding they told me to contact Netgear support.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi jbowlingknoxNG,
    Reading your statement above it tells me that your WAN IP address is NAT'd and not a public WAN IP.  Telstra in Australia do the same with their standard APN for mobile broadband.  It is firewalled for security reasons and I assume ATT are doing the same.  I know with Telstra we can call them up and ask for an APN to be provisioned on the SIM card which in fact assigns you a public WAN IP that works fine with Port Forwarding.  I suggest contacting ATT and asking to speak with a manager who maybe able to advise if ATT have an APN which assigns a public WAN IP.
    Kind Regards,
    ArodiD
