emr
Dec 12, 2016Tutor
R7100 lock on 4G/LTE
hi
is there a way of forcing the modem to LTE/4G, i.e. avoiding it to connect to a 3G network?
cheers
Hello emr
1. Launch a web browser from a computer or mobile device that is connected to the network.
2. Type http://www.routerlogin.net. A login window opens.
3. Enter the modem router user name and password. The user name is admin. The default password is password. The user name and password are case-sensitive. The BASIC Home page displays.
4. Select the ADVANCED > Setup > Mobile Broadband Settings. The Mobile Broadband Settings page displays.
Here is the settings for the sim card.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello emr
DarrenM
- emrTutor
hi
I'm sorry, my question was not precise enough. I do not have (yet) a R7100. I spare you the long description of the reason, but where I have to install it I need to force the modem to connect in 4G mode, vetoing anything else. I did not know if there was such an option in the setup and I could not find any specific information in the manual.
thanks for the info.
