copz1998
Jul 23, 2022Initiate
Reconnect to Device MR60 and T-Mobile
I recently moved away from Comcast/Xfinity Internet and hooked up with T-Mobile Home Internet. It works great. My old system includes two MR60 units mesh system, which also works great. When I plug the MR60 into the T-Mobile (Nokia) gateway, the MR60 gets immediate access. So, the home Internet system/access works great.
The problem comes in when I try to use my Netgear Nighthawk MR60 app on my iPhone. Under the Comcast account, the app worked great. Now, I keep getting an error message to reconnect (see screenshots). Is there an issue with T-Mobile home internet access and the MR60 mesh system? Any recommendations?
Thank you!
1. make sure icloud relay and private mac/ip address is disabled.
2. go into the tmobile gateway and put the netgears IP address into the tmobiles DMZ
