Markg1999
Dec 18, 2020Initiate
setting up new tv
Can I connect my tv to this with an ethernet cable ?
Should be able to.
Are you having issues?
If so what issues specifically are you having?
might want to post in the routers section and not the mobile hotspot/router section if its for a router
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
- Markg1999Initiate
I'm not havung problems, was just wondering. gettting the tv delivered next week..
Thanks
What's the TV? Does it support Ethernet? Wifi?
