kopiko's avatar
kopiko
Unable to save changes on Nighthawk M2
firmware version: NTGx24_10.19.03.00
last checked 13/6/22
modem version: SDX24_10.25.02.03
PRI 05.02
firmware build date 2021/09/01
I am unable to make any changes and save it. If I do it on the touch screen, it says
not saved
error saving changes
If through website it says "saving...restart required for it to be applied"
So I tried a factory reset 3 ways but doesn't seem to be complete because the wifi password doesn't change.
One way says "rebooting" and stays that way.
I tried holding the reset button and cycling the power. It gets to a stage saying "downloading software" and but after an hour nothing changes.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi kopiko
    Welcome to NETGEAR Community!
    May we please know the device SKU (e.g. MR1100-100NAS)? This can be checked on the box of the product or on the barcode label
    Have you tried using different browser? different device to change settings?
    Is the device powered on without the battery in?
    Blanca
    Community Team
    • kopiko's avatar
      kopiko
      Hello
      sku: mr2100-a1tlaus
      I usually have the router powered on by USB, no battery.
      Just now I tried with Chrome on a laptop changing the wifi profile from dual band to 2.4 only and it gives me a popup saying I will need to reboot the router for the changes to be applied. It says applied but when I reboot it says  "rebooting"
      I left it  for 5 minutes and pulled the power and repowered
      This time I tried it on Edge.
      Again, no battery, tried same thing but waited 7 minutes this time for it to reboot before pulling the power.
      I tried again, now with the battery plugged in, no USB, in Chrome. It is stuck on applying changes.
      I connected my mobile phone to the wifi and tried changing the wifi profile, same thing, stuck on "applying"
      • Blanca_O's avatar
        Blanca_O
        Hi kopiko,
        Aside from this issue, do you have connectivity issue such as connecting to the network or intermittent connection?
        As this is a Telsta SKU, have you tried contacting them regarding this concern?
        Blanca
        Community Team
