DanielN
Jul 13, 2017Aspirant
Unite Explore 815S DHCP not working
I'm having a problem today where DHCP is not assigning IP addresses and DHCP is turned on. I have this problem after doing a reset on the device or doing a reset from http://192.168.1.1. I connect my devices to the Unite Explore and IP address is not given out and I have to assign a static IP address on my device in the 192.168.1.x range for it to work? Anybody have any ideas why DHCP is not handing out an address? Even after a full reset and DHCP is on?
- DanielNAspirant
- DarrenMSr. NETGEAR Moderator
Hello DanielN
Have you checked to make sure the aircard has the latest firmware? Have you tried to factory reset the unit and set it up again?
DarrenM
- DanielNAspirant
Yes I've done the firmware check and it has the latest. I've also done the factory reset multiple times in the on-screen GUI as well as the web site. It will not serve out DHCP addresses. Everything else seems to be functioning if I assign my clients a static IP address. It is a really weird issue that has caused me to go back to using my Unite Pro.
Does anybody know how to initiate a warranty exchange without paying for Premium Support?
