PerP's avatar
PerP
USB tethering with a microprocessor or raspberry pi
For low power usage: Is it possible to use the Nighthawk M1 USB tethering on a Rasberry Pi running linux OR Raspbian ...or also using a small microprocessor system such as ESP32 (Which does not have an ethernet port)
    • PerP's avatar
      PerP
      Thanks....
      I am not focused on the power supply but on the ability to communicate via the USB port (serial) rather than needing an ethernet connection on a low power device. The RPI Does have ethernet, but in this case I am uncertain if Nighthawk supports linux.
      I posted thequestion where you suggested.
