OhioBen
Mar 15, 2016Aspirant
Using LG6100D on Verizon
I have a LG6100D gateway/router for my small business. At first I thought this would be a great way to stick it to the man (Time Warner Cable), instead I found a way to feel screwed by Sprint instead...
DarrenM
Mar 18, 2016Sr. NETGEAR Moderator
Hello OhioBen
You would have to check with verizon to see if they can activate the device but this device was intended for sprint use only.
DarrenM
- OhioBenMar 23, 2016Aspirant
DarrenM, thank you for your reply. Do you know if there are any features intrinsic to this physical device or the firmware that would prohibit its use on non-Sprint carriers?
- TGabrieleJul 06, 2016Tutor
Not sure if you ever got your answer, but none of Sprint and Verizon's LTE bands are the same, so I doubt you'd get LTE service on this device, probably just 3G.
