shiphranita
Mar 29, 2018Aspirant
Verizon Novatel USB760
I have a Novatel USB760 stick from Verizon that I am trying to use to connect with my new Netgear Nighthawk AC3200. The USB stick won't connect at all. The connection is usually automatic on my Cradlepoint MBR95, but I can't get it to connect to the Nighthawk in either the 2.0 or 3.0 USB slots. Can anyone help? Or is it just not compatible? :(
- JasonNNETGEAR Employee Retired
Hi shiphranita,
I could not find anything on the compatibility between the Verizon Novatel USB760 & the NETGEAR AC3200.
Please contact support and they will be able to help you with the issue.
http://www.netgear.com/support/contact.aspx
Please let me know. :]
- Jason N
Hi shiphranita,
I wanted to check in with you and see if your have got this issue resolved by support.
- Jason N
- shiphranitaAspirantWell the resolution is that it won’t work.
Hi shiphranita,
Thank you for confirming because that was the only results I have seen when researching on the compatibility.
- Jason N
