shiphranita's avatar
shiphranita
Verizon Novatel USB760
I have a Novatel USB760 stick from Verizon that I am trying to use to connect with my new Netgear Nighthawk AC3200. The USB stick won't connect at all. The connection is usually automatic on my Cradlepoint MBR95, but I can't get it to connect to the Nighthawk in either the 2.0 or 3.0 USB slots. Can anyone help? Or is it just not compatible? :(
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi shiphranita,
    I wanted to check in with you and see if your have got this issue resolved by support.
    Please let me know. :]
    - Jason N
      • JasonN's avatar
        JasonN
        Hi shiphranita,
        Thank you for confirming because that was the only results I have seen when researching on the compatibility.
        - Jason N
  • JasonN's avatar
    JasonN
    Hi shiphranita,
    I could not find anything on the compatibility between the Verizon Novatel USB760 & the NETGEAR AC3200.
    Please contact support and they will be able to help you with the issue.
    http://www.netgear.com/support/contact.aspx
    - Jason N
