lund33
Feb 23, 2018Follower
WAC120 DETAILED installation help for newb
I am about ready to put this thing in a vice and burn it. I do not understand anything that is not plug and play. I have had this thing for almost a year and I cannot for the life of me figure out how to get it to work. I have searched every combination possible in google and youtube to find help as to how to set this WAP up with the same, abbreviated instructions at the end of every search. I NEED STEP BY STEP INSTRUCTIONS FO RHOW TO SUCCESSFULLY CHANGE MY IP ADDRESS TO STATIC WITHIN WINDOWS 7 PROFESSIONAL 64-BIT. I HAVE TRIED AND I CANNOT GET TO THE NETGEAR MENU AS DESCRIBED IN THE INSTRUCTIONS. WHAT AM I DOING WRONG!?!?!?!?!?!?!?
- JasonNNETGEAR Employee Retired
Hi lund33,
I'm sorry you are having a difficult time setting up your WAC120. The link below is a step by step guide to set up your WAC120.
http://www.downloads.netgear.com/files/GDC/WAC120/WAC120_IG_5June2014.pdf
As for changing your PC's ip address to static. You can youtube "Change my ip address to static windows 7". There will be a list of results that shows you step by step on how to proceed.
Please let me know if this fixes your issue. :]
- Jason N
Hi lund33,
I just wanted to check in and see if this has fixed you issue.
Please let me know :]
- Jason N
- Juliwade01AspirantCan anyone help. I had everything set up and running fine, but after my son rebooted our main hub (I use the wac to extend the Wi-Fi so I can use in my attic room) the previously connected devices all see it but fail to obtain the up address
- MAGADEGuide
Hi, perhaps a conflict IP adresse due to DHCP reservation faulty.
The reboot perhaps stop IP lease.
try to assign IP adresse of router LAN port or hub LAN port in a DHCP RESERVATION.
