david70
Aug 13, 2015Follower
web admin password not enabled
Hello everybody, I have bought a aircard 785 mobile hotsport and when I try to set the administrator password in the web home page setting, but it isn't enabled. Any suggestions, thanks.
Davide
- go4dutchAspirant
same problem here after upgrading last firmware !!!!!!
- DarrenMSr. NETGEAR Moderator
Hello go4dutch and david
I was able to test the 785 aircard I have and was able to change the admin password. You may want to try a different browser if its not working for you I used chrome and it work. next make sure you are logging in as admin so it allows you to change settings. if those dont work try to do a factory reset on the aircard. hope to hear your feedback
DarrenM
If this issue is still happening can you give me some screenshots so I can pass them on to engineering
Thanks
DarrenM
