LC78's avatar
LC78
WNCE 2001 problems
Any help would be appreciated,
I have a WNCE2001 and according to documents if the red on the power light stays on, power source is low. However I replace the Transformer with a new one and the light on power led remains red. any suggestions?
  • It might be time to call it. It could be a hardware failure that's manifesting as the red light.
    If you're replaced the power supply and tried resetting it, it might be time to stop investing time/money in getting it working.
    Its a 10 year old device that is pretty base level.
  • plemans's avatar
  • Thank you,
    By any chance anyone happens to know of a similar device with similar dimentions that will work with a Netgear N600 router? I'm looking for compability and reliable.
    • plemans's avatar
      Many of netgears extenders have an ethernet out port. You could go for something like the EX3700 which is a n600 device. I believe you can even set it up in fastlane so it sets the 5ghz or the 2.4ghz as the dedicated backhaul
