dentspen
Dec 13, 2017Aspirant
1G Copper SFP on M4300-8X8F Odd Behavior
I am having trouble with some 1G copper SFPs in a M4300-8X8F (XSM4316S) switch (I actually have two of these switches and both of them have the same problem with these SFPs) and was wondering if som...
Retired_Member
Dec 13, 2017Hi dentspen,
Welcome to the community!
Could you please run below CLI command when you insert the fiber module?(assume the port 1/0/1)
show fiber-ports optics 1/0/1
show fiber-ports optics-info 1/0/1
show fiber-ports optics-eeprom 1/0/1
show running-config interface 1/0/1
EricZ
NETGEAR employee
- dentspenDec 14, 2017Aspirant
I'm not sure if you wanted the information on the Copper SFP I am having problems with or the Fiber SFP+ that I mentioned, so I am going to provide the output for a port with a fiber SFP and a port with a copper SFP so that you can see both. I apologize for my confusion.
Port 1/0/1 (contains a 10G Fiber SFP+)
This is the type of SFP that DOES work
(M4300-8X8F) #show fiber-ports optics 1/0/1
Output Input Port Temp Voltage Current Power Power TX LOS Fault [C] [Volt] [mA] [dBm] [dBm] Fault Status -------- ---- ------- ------- ------- ------- ----- --- ------------- 1/0/1 19.7 3.345 23.9 -1.915 -3.099 No No No Fault(M4300-8X8F) #show fiber-ports optics-info 1/0/1
Link Link Nominal Length Length Bit 50um 62.5um Rate Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance -------- ---------------- --- ---- ---------------- ---------------- ----- ---- ---------------- 1/0/1 FiberStore 22 11 F1700200006 SFP-10GLRM-31 10300 10GBase-LR(M4300-8X8F) #show fiber-ports optics-eeprom 1/0/1
Port 1/0/1 vendor_name = FiberStore vendor_sn = F1700200006 date_code = 170929 vendor_pn = SFP-10GLRM-31 vendor_rev = eeprom data = 03 04 07 20 00 00 00 00 00 00 00 06 67 00 00 00 ... ........g... 16 0b 00 00 46 69 62 65 72 53 74 6f 72 65 20 20 ....FiberStore 20 20 20 20 00 00 00 00 53 46 50 2d 31 30 47 4c ....SFP-10GL 52 4d 2d 33 31 20 20 20 20 20 20 20 05 1e 00 ae RM-31 .... 00 1a 00 00 46 31 37 30 30 32 30 30 30 30 36 20 ....F1700200006 20 20 20 20 31 37 30 39 32 39 20 20 68 90 01 65 170929 h..e 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
NOTE: Port 1/0/1 is configured as a stack port so no configuration shows up in this next command
(M4300-8X8F) #show running-config interface 1/0/1
!Current Configuration: ! interface 1/0/1 exit
Port 1/0/2 (contains a 1G Copper SFP)
This is the type of SFP that does NOT work
NOTE: This SFP is not fiber so these are all N/A
(M4300-8X8F) #show fiber-ports optics 1/0/2
Output Input Port Temp Voltage Current Power Power TX LOS Fault [C] [Volt] [mA] [dBm] [dBm] Fault Status -------- ---- ------- ------- ------- ------- ----- --- ------------- 1/0/2 N/A N/A N/A N/A N/A N/A N/A No Fault(M4300-8X8F) #show fiber-ports optics-info 1/0/2
Link Link Nominal Length Length Bit 50um 62.5um Rate Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance -------- ---------------- --- ---- ---------------- ---------------- ----- ---- ---------------- 1/0/2 FiberStore 0 0 A07C0700046 SFP-GB-GE-T 1300 0000 1000T(M4300-8X8F) #show fiber-ports optics-eeprom 1/0/2
Port 1/0/2 vendor_name = FiberStore vendor_sn = A07C0700046 date_code = 171207 vendor_pn = SFP-GB-GE-T vendor_rev = 000 eeprom data = 03 04 00 00 00 00 08 00 00 00 00 01 0d 00 00 00 ................ 00 00 64 00 46 69 62 65 72 53 74 6f 72 65 20 20 ..d.FiberStore 20 20 20 20 00 00 09 5b 53 46 50 2d 47 42 2d 47 ...[SFP-GB-G 45 2d 54 20 20 20 20 20 30 30 30 30 00 00 00 d3 E-T 0000.... 00 01 00 00 41 30 37 43 30 37 30 30 30 34 36 20 ....A07C0700046 20 20 20 20 31 37 31 32 30 37 20 20 00 00 00 5f 171207 ..._ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
NOTE: VLAN 3 is my management VLAN
(M4300-8X8F) #show running-config interface 1/0/2
!Current Configuration: ! interface 1/0/2 link debounce time 5000 spanning-tree edgeport switchport mode access switchport access vlan 3 exit
Thanks for your help :)
- Retired_MemberDec 14, 2017
Hi dentspen,
Sorry to make you confusion.
I just want to get the info for the issue port. I mean please insert the fiber module and cable to the issue port, and then run the command to get the detailed info.
Thanks.
- dentspenDec 15, 2017Aspirant
Thank you for your response, Retired_Member,
The issue I have is with a Copper Ethernet (RJ45) SFP module, not with a fiber module. I have plugged the copper module into port 1/0/2. Here are the outputs from the commands that you asked for:
