NajdAlshaye
Oct 18, 2025Aspirant
1G SFP Compatibility on M4300-12X12F
Hello, I am trying to connect a Netgear M4300-12X12F switch to a Cisco N540X-6Z18G-SYS-A switch using 1G SFP modules. I noticed that: 10G SFP+ modules work perfectly between the switches...
schumaku
Oct 19, 2025Guru - Experienced User
The Data sheet is listing specifically:
AGM731F 1000BASE-SX SFP GBIC (Multimode)
AGM732F 1000BASE-LX SFP GBIC (Single mode)
AGM734 1000BASE-T RJ45 SFP GBIC
Netgear does not support any other SFP or SFP+ modules but these explicitly listed on the data sheet
https://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
