mpitech
Feb 18, 2019Aspirant
2 stacks lag
I need to link a 4-switches stack of S3300 to a 2-switches stack of M4300. What would be the best practices here ? Specifically, is setup a 8-ports LAG (linking each S3300 to the 2 M4300) a good idea...
- Feb 19, 2019
Hi mpitech,
Welcome to our community! :)
It seems that you wanted to link these 2 stacks of switches. That's really a good idea on connecting it with 8-ports LAG as long as it is properly configured. I don't think that it is possible to stack both S3300 with M4300 as it is not on the same family version.
JohnC_V
Feb 19, 2019NETGEAR Employee Retired
Hi mpitech,
- mpitechFeb 20, 2019Aspirant
OK thanks.
- JohnC_VFeb 20, 2019NETGEAR Employee Retired
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
