robfantini's avatar
robfantini
XS708T lag to m5300 stack
Hello
I am having trouble getting a lag to work from M5300 stack to XS708T
We do have lags working from M5300 to M4100 .
The lag settings on the M5300 :
interface lag 9
auto-voip protocol-based
description 'to mezz switch'
set igmp mrouter interface
dhcp l2relay
mtu 9216
at the XS708T:
interface xg7
addport lag 1
exit
interface xg8
addport lag 1
exit
interface lag 1
port-channel load-balance 6
when onsite I'll remove the mtu 9216 on the m5300.  just noticed that.
in the mean time  if you see something else I could try please let me know.
  • Hi fbcsupport ,
    Thanks for your quickly response.
    We has received techsupport file just sent.
    After analysis the configuration on both M5300&XS708T.
    The LAG interface may have inconsistent configuration so that communication fail.
    Here is configuration on M5300:
    interface lag 9
    dhcp l2relay
    vlan pvid 8
    vlan participation include 3,7-8,10,15,20,25,41,70,80,90,199
    vlan tagging 3,7,10,15,20,25,41,70,80,90,199
    exit
    Here is configuration on XS708T:
    interface lag 1
    description 'to mezz'
    no port-channel static   >>>this is mean LACP mode
    To make both two LAG interface work together,
    Please set the same VLAN configuration /MTU on XS708T too.
    Let me know about result after set same configuration on both LAG interface.
  • Hi robfantini ,
    Welcome to NETGEAR online community! :)
    The default LAG type on M5300 is LACP as managed switches behavior.(the same as M4100)
    But the default LAG type on XS708T is static as smart switches behavior.
    So maybe the LAG type is different on M5300/XS708T so that can't work together.
    Please try with following suggestion on M5300 and XS708T:
    1. Make the LAG type as same on M5300/XS708T, Such as: change LAG type on XS708T to LACP.
    2, Make the LAG load-balance mode as same on  M5300/XS708T, Such as: load balance mode 6 or others(based on your network condition)
    If above two suggestion don't make LAG get work between M5300 and XS708T.
    Please send techsupport file to us for both M5300/XS708T, then we will analysis and debug further.
    Here is guideline about how to get Techsupport file on Smart/Manage switches.
    https://kb.netgear.com/31438/How-do-I-send-diagnostic-files-from-my-Smart-Switch-to-NETGEAR-community-moderators
    https://kb.netgear.com/31439/How-do-I-send-diagnostic-files-from-my-Managed-Switch-to-NETGEAR-community-moderators
    • fbcsupport's avatar
      fbcsupport
      Hello,  I tried to set the lags as suggested,   ports lit up at both switches , however  network connection failed .
      attached are the support files.
      having trouble with extension ,  will add .pdf even though not a pdf. that did not work.
      i just reread the links,  so will send to : [email protected]
      • DanielZhang's avatar
        DanielZhang
        NETGEAR Expert
        Hi fbcsupport ,
        interface lag 9
        dhcp l2relay
        vlan pvid 8
        exit
        interface lag 1
ProSupport for Business
