robfantini
Nov 09, 2020Aspirant
XS708T lag to m5300 stack
Hello I am having trouble getting a lag to work from M5300 stack to XS708T We do have lags working from M5300 to M4100 . The lag settings on the M5300 : interface lag 9 auto-voip protoc...
- Nov 10, 2020
Hi fbcsupport ,
Thanks for your quickly response.
We has received techsupport file just sent.
After analysis the configuration on both M5300&XS708T.
The LAG interface may have inconsistent configuration so that communication fail.
Here is configuration on M5300:
interface lag 9
auto-voip protocol-based
description 'to mezz switch'
port-channel load-balance 6
set igmp mrouter interface
dhcp l2relay
vlan pvid 8
vlan participation include 3,7-8,10,15,20,25,41,70,80,90,199
vlan tagging 3,7,10,15,20,25,41,70,80,90,199
exitHere is configuration on XS708T:
interface lag 1
description 'to mezz'
no port-channel static >>>this is mean LACP mode
port-channel load-balance 6To make both two LAG interface work together,
Please set the same VLAN configuration /MTU on XS708T too.
Let me know about result after set same configuration on both LAG interface.
fbcsupport
Nov 10, 2020Aspirant
Hello, I tried to set the lags as suggested, ports lit up at both switches , however network connection failed .
attached are the support files.
having trouble with extension , will add .pdf even though not a pdf. that did not work.
i just reread the links, so will send to : [email protected]
DanielZhang
Nov 10, 2020NETGEAR Expert
Hi fbcsupport ,
interface lag 9
dhcp l2relay
vlan pvid 8
exit
interface lag 1
- robfantiniNov 11, 2020Aspirant
thank you.
we had the vlans set, a factor reset was done and neglected to readd the vlans to lag. after redoing all is good
