Jeffhtg
Feb 06, 2025Initiate
4350 multiple routers for a/v
I have a video over ip system (transmit receiver bluestream to send hdmi to monitors on a network) 4x 4350 switches with sfp modules to link is 'stacking' how i need to configure this? They will ...
LaurentMa
Feb 10, 2025NETGEAR Expert
Hi Jeffhtg
I would temper adithya11 response a bit (big thanks to him/her though) - and go simpler:
Please use the step by step application notes here: https://www.netgear.com/hub/business/av/av-tech-guides/
When onboarding your AV Line switches (M4350) in Engage, firmware will be updated. Please use approved 10G or 25G modules, and no - stacking is absolutely not advised. Please keep the switches standalone in Engage (www.netgear.com/engage), with enough bandwidth for the video streams. The only configuration you need to do is under Site Settings, edit the default VLAN 1, and apply the Video+Audio AES67 profile. Apply until the end, and Save on the upper right.
NETGEAR AV is certified at Bluestream, and we have a dedicated Bluestream profile coming in the next weeks - but for now you will be perfectly covered with the Video+AES67 Audio generic profile, if you follow the app notes above!
You can get back to us for any support, sending an email to [email protected]
- GreenTurtleFeb 19, 2025Aspirant
Just to dig into this a bit more, can you explain why you don't recommend stacking the switches?
- LaurentMaFeb 19, 2025NETGEAR Expert
Hi GreenTurtle ,
You'll find what we are supporting for IT (stacking everything everywhere) and what we are supporting for AV (a stack of 2 switches at the core only, for redundancy) on the M4350 datasheet https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf, pages 26 and 27.
In a stack, all the multicast is replicated to facilitate the non-stop forwarding (losing a switch without losing multicast on other members of the stack). So this is not a solution for AV over IP.
But, with the Engage controller, you still have one single pane of glass - under Site Settings you manipulate the whole site with your VLAN(s) etc. So it's removing the need for configuring standalone switches, like in a stack. I hope it will help you!
Ah, perfect. I've seen the IT method in several netgear posts around the www, but hadn't seen the AV recommendations.
