jaypaterson's avatar
May 02, 2012
7000 series CLI Commands
Hello,
We have recently deployed an XSM7224S and serveral GSM7252PS switches, connected together with OM3 fiber and AXM761 GBIC modules.
We're having some Layer 1/2 connectivity issues (which I will make another post about) that NetGear support have made some suggestions on using the CLI to change. Is anyone aware of how to restart/reboot a 7000 series switch from the CLI. It would be very helpful to know how to do this, rather than pulling the plug or accessing the HTTP admin interface to do this. Can't seem to find any reference to such a command in the CLI reference.
Kind regards and thanks,
Jay
1 Reply
  • Hi Folks,
    Got teh solution from Netgear Support. The command to reset the switch from the CLI (priveledged mode) is...
    reload
    Hope that helps someone.
