masc1
Aug 03, 2017Tutor
8-Port Managed Switch Trunking
Hi! I'm looking for a Netgear 8-port switch with Trunking support. Is such a porduct available from Netgear? Thank you
- Aug 04, 2017
Hi masc1,
Welcome to the community!
Here is the list of our Smart switches that supports trunking.
JohnC_V
Aug 08, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
