Elad6L's avatar
Elad6L
Adding a static L2 multicast address
Hi, I'm trying to enable multicast L2 address routing for specific Mac-Add- 01:50:43:00:00:03 (this is used by a propreitary discovery protocol on my setup). When I attempt to add this address, I ge...
  • DaneA's avatar
    DaneA
    Oct 05, 2021
    Elad6L,
    I apologize for the late response. Could it be that the feature you are looking for is MAC Filtering?  If yes, go to Security > Traffic Control > MAC Filter.  It basically allows the user to set a static MFDB entry.
    If ever you are not looking for MAC Filtering, kindly provide further details about what you want to implement as well as how are the devices are connected.  It would be best if you post a detailed diagram of your network setup.
    DaneA
    NETGEAR Community Team
ProSupport for Business
