John_Howard
Dec 21, 2021Tutor
Are NETGEAR products vulnerable to LOG4J ?
Hello. Can we please get a clear message from Netgear about the LOG4J vulnerability (CVE-2021-44228) please. The answer should include (where known): Which products do not use LOG4J Which prod...
John_Howard
Dec 21, 2021Tutor
Hi Plemans.
Thanks. I already read this.
It is not detailed enough and is just posted by an admin.
They need to release a proper statement. For example this is the DELL security bulletin: https://www.dell.com/support/kbdoc/en-sg/000194414/dell-response-to-apache-log4j-remote-code-execution-vulnerability
Dec 21, 2021Guru - Experienced User
A proper statement would be great.
But you're on the community support forum where members of the public help out.
The best you're going to get on the community forum is literally a post from an admin.
there normally isn't even an admin on here.
- John_HowardDec 23, 2021Tutor
Hi Plemans
Good point, I had not fully appreciated that.
Though I had seen the posts from Christine the Admin, so hopefully they do see my post and respond.
Thanks and Merry Christmas
