fredericallaert
Jun 08, 2020Aspirant
ARP entry for gateway does not expire
We are using Barracuda firewalls in a cluster configurations. Whenever a failover of the cluster occurs, the ARP entry (incidentally also the default gateway for the switch) on the switch never expires, the switch retains the MAC address of the old unit while the rest of the network picks up on the new MAC of the failover unit. Any ideas why the switch would treat the gateway MAC differently, basically ignoring the ARP timeout (despite having set the ARP timeout to the minimum - 15 seconds)?
- Anonymous
Welcome to Community!
Could you please run command 'show arp' and collect the output information?
In my side, it's work fine when I change ARP Age Time to 60s. You can see after about 60s, the ARP entry(111.1.1.2) is removed success.
Below is my device output info:
(M4300-48XF) #show arp
Age Time (seconds)............................. 60
Response Time (seconds)........................ 1
Retries........................................ 4
Cache Size..................................... 760
Dynamic Renew Mode ............................ Disable
Total Entry Count Current / Peak .............. 2 / 2
Static Entry Count Configured / Active / Max .. 0 / 0 / 128
IP Address MAC Address Interface Type Age
111.1.1.1 8C:3B:AD:6A:9D:0B vlan 1 Local n/a
111.1.1.2 00:00:4A:52:02:2A vlan 1 Dynamic 0h 0m 17s
(M4300-48XF) #(M4300-48XF) #show arp
111.1.1.2 00:00:4A:52:02:2A vlan 1 Dynamic 0h 0m 57s
Total Entry Count Current / Peak .............. 1 / 2
(M4300-48XF) #Hope it helps!
Eric
- fredericallaertAspirant
Hi Eric,
Please find the output below. Nothing peculiar to see in the output, but what you can see is that the "Type" field of the IP-address 152.1 comes back as "gateway" in your output it's not BTW) because it's the default gateway address for the switch.
When the firewall cluster fails over to the secondary unit this MAC address will not expire and keeps trying to reach out to this IP-address on the wrong MAC. Other devices in the network pick up the new MAC address after the 15s expiration, the switch doesn't
192.168.152.1 00:10:F3:86:C4:7C vlan 1 Gateway 0h 0m 3s
192.168.152.2 00:10:F3:86:C4:7C vlan 1 Dynamic 0h 0m 0s
192.168.152.3 00:10:F3:8B:A4:5F vlan 1 Dynamic 0h 0m 0s- Anonymous
In your output, I see 152.1 and 152.2 use same MAC address, is it correct?
What's the IP of the firewall?
What's the IP of the Switch?
Could you please run command 'show mac-addr-table' and collect the output info?
