top_of_rack_var
May 05, 2025Tutor
AutoInstall not working on reset switches
I'm working on setting up an autoconfig environment using M4300/M4350 series switches. There doesn't appear to be much documentation for this. The only thing I've been able to find are some notes i...
schumaku
May 07, 2025Guru - Experienced User
Auto Install was never enabled by default on any Netgear switche model, it always is a manual action required e.g. from the console.
Same applies to my knowledge also to the Cisco switches and routers.
