orbimesh's avatar
orbimesh
Switch stipped working
Have an Orbi rbk50 connected to optimum router . From Orbi have a multiport Luxul switch . Wired connections stopped working . Tried rebooting , turned on off DHCP settings and rebooted . Any tips ?
  • Hi,
    I'm glad you sorted the issue :)
    Looks like you probably created a loop on your switch which caused your issues?
    CheerZ
  • Hi,
    Have you checked the ethernet cables used for the switch?  If the ethernet cables are ok then your switch could be 'toast'?  Have you also tried directly connecting to the Orbi to check that the ethernet port that the switch is connected to is ok?
    CheerZ
    • orbimesh's avatar
      orbimesh
      If I unplug all the lan ports on Orbi works well for WiFi. Satellites change to magenta color too. I’ll test with new cables again . Just got new Firmware update installed as well. Not sure if switch from Luxul and Orbi dhcp fighting (if that’s how to say it !)
  • FURRYe38's avatar
    What is the MFr and model if this switch your using.
    There are known incompatibilies with some switches that are managed or have Green Ethernet features.
    • orbimesh's avatar
      orbimesh
      Looks like had a wire plugged in both ends to a connected switch . Working now ! Thanks again .
      • FURRYe38's avatar
        Glad it was a simple fix. Please mark your thread as solved.
        Enjoy.
