Salden
May 21, 2021Aspirant
ax743 visible like ax745
I found a problem in my switch M5300-28G when I decided to buy another switch M5300-52G and stack them. It turned out that the ax743 module is displayed in the system as ax745 and does not really wor...
DaneA
Jun 10, 2021NETGEAR Employee Retired
Welcome to the community! :)
Just to verify does the AX743 module shows in the system as AX745 on both of your M5300-28G and M5300-52G (even they are not stacked)?
DaneA
NETGEAR Community Team
- SaldenJun 11, 2021Aspirant
Good day!
I bought a new module for testing, and it is detected correctly. Most likely the problem is in the firmware of the old module.
Here's a new module (s/n 24x17b5600050):
AX743 new
Here is an old one and not working properly (s/n 24x1275b0011e):
AX743 old
Is it possible to install the correct firmware on the old module?
Best regards, Denis.
- DaneAJun 15, 2021NETGEAR Employee Retired
I inquired your concern to the higher tier of NETGEA Support. According to them, it would be best to open a support ticket with the NETGEAR Support Team here at anytime. Further investigation is need on why your old AX743 was showing as AX745 on your M5300 switches.
DaneA
