jg1
Jan 09, 2017Aspirant
AXC763 SFP+ DAC CABLE with Intel X710
Is there any known compatibly issue with the AXC763 SFP+ DAC CABLE and the Intel X710 Converged Adapter? I can't seem to get a link with this. I'm using a M4300-12X12F but have also tried directly co...
LaurentMa
Jan 09, 2017NETGEAR Expert
Hi jg1
No there's no known compatibility issue with Intel® adapters.
I would advise to run latest 12.0.2.9 software on your M4300-12X12F, since we fixed some DAC issues with that release.
Can you upgrade your 12X12F first thing following the release note indications?
On a separate note, Intel® NICs usually require Intel SFP and SFP+ modules, they are locked or very picky like most servers / storage are (requiring same brand DACs).
That's the reason why we strive to support Third-Party DAC cables, as long as they are MSA standard. Another option could be, try the Intel® Ethernet SFP Twinaxial Cable 3 meters XDACBL3M and let us know how it goes with 12.0.2.9 latest software.
- jg1Jan 09, 2017Aspirant
I'll get the firmware updated on the switches.
According to Intel the card should "support direct attach cables that comply with SFF-8431 v4.1 and SFF-8472 v10.4 specifications"
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006754.html
Thanks for the reply.
- Retired_MemberJan 09, 2017
Hi jg1,
Welcome to Netgear Community!
I tried in my local environment. It's ok. I Connect M4300-12X12F to PC(Inter X710) with AXC 763 DAC Cable.
So I suggest you can update your Inter X710 adapter dirver and try again.
Below is the detailed information:
1. Switch fiber port info:
2.Inter X710 info:
Regards
Ericz
Netgear Employee
- jg1Jan 10, 2017Aspirant
I was able to update the firmware on the M4300-12X12F but it had no effect. I'll look to update the x710 firmware.
