jg1
Jan 09, 2017Aspirant
AXC763 SFP+ DAC CABLE with Intel X710
Is there any known compatibly issue with the AXC763 SFP+ DAC CABLE and the Intel X710 Converged Adapter? I can't seem to get a link with this. I'm using a M4300-12X12F but have also tried directly co...
jg1
I'll get the firmware updated on the switches.
According to Intel the card should "support direct attach cables that comply with SFF-8431 v4.1 and SFF-8472 v10.4 specifications"
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006754.html
Thanks for the reply.
Retired_Member
Jan 09, 2017Hi jg1,
Welcome to Netgear Community!
I tried in my local environment. It's ok. I Connect M4300-12X12F to PC(Inter X710) with AXC 763 DAC Cable.
So I suggest you can update your Inter X710 adapter dirver and try again.
Below is the detailed information:
1. Switch fiber port info:
2.Inter X710 info:
Regards
Ericz
Netgear Employee
- jg1Jan 10, 2017Aspirant
I was able to update the firmware on the M4300-12X12F but it had no effect. I'll look to update the x710 firmware.
I updated the Firmware and Driver on the card and still no link. I switched the card to a Windows 2008 server and still no link. I'm not sure what else it could be besides the cable.
- atianJan 10, 2017Aspirant
1) do you have more DAC763? Could you try another one?
2) Could you provide the output of 'show fiber-ports optics-info all'?- jg1Jan 11, 2017Aspirant
Port 10 is connected to the x710.
I've tried 3 different AXC763 cables with none working.
(M4300-12X12F) #show fiber-ports optics-info all
Link Link Nominal
Length Length Bit
50um 62.5um Rate
Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance
1/0/1 NETGEAR 0 0 16092D0060 AXC761 10300 A DAC
1/0/2 NETGEAR 0 0 16142D0135 AXC761 10300 A DAC
1/0/3 NETGEAR 0 0 16142D0453 AXC761 10300 A DAC
1/0/4 NETGEAR 0 0 16092D0011 AXC761 10300 A DAC
1/0/5 NETGEAR 0 0 16092D0132 AXC761 10300 A DAC
1/0/6 NETGEAR 0 0 16142D0316 AXC761 10300 A DAC
1/0/7 NETGEAR 0 0 16142D0279 AXC761 10300 A DAC
1/0/8 NETGEAR 0 0 16142D0519 AXC761 10300 A DAC
1/0/10 NETGEAR 0 0 16191D0035 AXC763 10300 A DAC
