bzt
Nov 04, 2020Tutor
AXM762 APC/UPC?
Hi folks, I'm trying to figure out which fiber patch cables I need for a new M4300 setup using AXM762 SFP+ modules, and coming up short on whether they're APC or UPC. https://community.netgea...
bzt
Nov 04, 2020Tutor
Thanks, schumaku! I'm buying patch cables to connect the LC AXM762 to the existing SC ports in the building. The product page turns out to be a little inconsistent, image-wise - the low resolution image is of the AXM761 (black pull tab), and the high resolution image is the AXM762 (blue pull tab), but that makes sense with the PC/UPC color coding you mentioned.
Anyone know if the AXM762 has a datasheet somewhere? I'm just coming up with the Installation Guide , which is a little brief.
schumaku
Nov 04, 2020Guru - Experienced User
Don't count to much on the marketing images, I had more the installer in front of the rack in mind when talking about the colour markings.
SFP and SFP+ nodules are industry standard material - all are made similar. You might want to google for the product number, various second source available - off Netgear assistance and support however.
