bzt's avatar
bzt
Tutor
Nov 04, 2020
AXM764 on M4300-52G
Just confirming that the AXM764 plays well with the M4300-52G:
From the product page:
https://www.netgear.com/business/products/switches/modules-accessories/axm764.aspx :
  • Fits into SFP+ interfaces of M5300, M6100, M7100 and M7300 series Managed Switches
  • Fits into SFP+ interfaces of select Smart and Plus Switches
No mention of the M4300 line.
However, from the M4300 Hardware Installation Guide:
https://www.downloads.netgear.com/files/GDC/M4300/M4300_HIG_EN.pdf?cid=wmt_netgear_organic :
The switch supports the following NETGEAR SFP and SFP+ transceiver modules and cables:
• Long-reach fiber transceiver modules:
  • - AGM732F. SFP transceiver 1000BASE-LX, SFP single mode LC GBIC
  • - AXM762. SFP+ transceiver 10GBASE-LR, SFP+ single mode LC GBIC
  • - AXM764. SFP+ transceiver 10GBASE-LR Lite, SFP+ single mode LC GBIC
I'm assuming I can trust the specific over the general? Thanks in advance!
  • Yes, you should be fine. Guess the product accessories listing was created long before the first M4300 Series switches appeared on the market.
    Less would be more LaurentMa - thank you!
1 Reply
  • schumaku's avatar
    schumaku
ProSupport for Business
