HolmesNetworks's avatar
Aug 08, 2024
M4300-52G-PoE+ and UWB-XG
Can a M4300-52G-PoE+ Ethernet port power a Unifi BaseStationXG (UWB-XG)? The UWB-XG maximum needed wattage for the UWB-XG is 31w (source: Quick Start Guide). It also requires 802.3bt, but it's the power supplied that matters for that spec correct?
  • We tested it anyhow and it does in fact power the BaseStationXG, but like you also mentioned won't meet the maximum power requirement. We will use the included PoE injector with the XG to compensate. Thank you for the alternate suggestions for powering the switch.
  • RennaD's avatar
    RennaD
    NETGEAR Moderator
    Hello HolmesNetworks,
    The power available to the powered device (PD) for PoE+ (802.3at) is 12.95W-25.5W while PoE++ (802.3bt) is 25.5W-51W. Since the UWB-XG requires 31W the PoE+ would not be enough. It needs PoE++ (802.3bt) which the M4300-52G-PoE+ does not support.
    Some of NETGEAR L3 switches that supports PoE++ are M4250-40G8XF-PoE++(GSM4248UX), M4350-48G4XF(GSM4352)and M4350-44M4X4V(MSM4352). For the whole list you can check the link below:
    https://www.downloads.netgear.com/files/netgear/pdfs/NETGEAR-Interactive-Catalog.pdf
    Have a lovely day,
    RennaD
    Netgear Team
    • schumaku's avatar
      schumaku
      RennaD wrote:
      • M4250-40G8XF-PoE++(GSM4248UX)
      ... 40 GbE 802.3bt port, plus eight SFP+ module slots, so no PoE++ there only.
      RennaD wrote:
      • M4350-48G4XF(GSM4352)
      ... 48 GbE 802.3bt port, plus eight SFP+ module slots, so no PoE++ there only.
      RennaD wrote:
      • M4350-44M4X4V(MSM4352)
      ... 44x 2.5G (MultiGig) ports, plus *just" four, 4x10G/Multi-gig with PoE++ there only.
      For better assistance selecting the right Manged Switch for your purposes and your network, I'll recommend to contact the  Pro AV and network design service team [email protected]
      As I wrote in reply to your other thread (and you alredy discovered this possibility)
      Your existing Netgear XS7xxT switch can be used, It just requires using the UWB-XG Gigabit PoE++ adapter 50V DC, 1.2A (Included with the UWB-XG from what I understand, I -guess- this is an in-line power injector) you can install near to the switch, or near to the AP.
      -Kurt.
ProSupport for Business
