dt987's avatar
dt987
Failover UDP DHCP relay M4300-52G-PoE+
Hi All,
I'm currently using UDP DHCP relay on M4300-52G-PoE+ switch to point to a DHCP server in our network per VLAN interfcae, server itself is Windows 2012R2 VM. DHCP works perfectly fine.
Now, let's say I want to add another DHCP server for redundancy. Does anyone know if it is possible to have primary and secondary UDP DHCP relays? It seems I can add another entry for relay with a different DHCP server IP address, but it's not clear how it will prioritize (or load balance) DHCP requests between servers? I guess the goal is to use one DHCP server as primary and another one as a backup in case if primary is not responding.
Both Windows DHCP server will be setup in failover.
Thanks!
  • dt987,
    Unfortunately, we cannot add another DHCP UDP relay on the VLAN interface.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi dt987,
    I don't think that it is recommended to have a failover on DHCP. As the DHCP server doesn't have the capability to detect if it still online or not. This will only cause an IP conflict on your network. It might be better if you will just set the clients that you have to static ip in order to retain the IP addresses. Even if it fails, it still have its own IP.
      • JohnC_V's avatar
        JohnC_V
        dt987,
ProSupport for Business
