dt987's avatar
dt987
Failover UDP DHCP relay M4300-52G-PoE+
Hi All,   I'm currently using UDP DHCP relay on M4300-52G-PoE+ switch to point to a DHCP server in our network per VLAN interfcae, server itself is Windows 2012R2 VM. DHCP works perfectly fine. No...
  • JohnC_V's avatar
    JohnC_V
    Jul 12, 2017
    dt987,
    Unfortunately, we cannot add another DHCP UDP relay on the VLAN interface.
ProSupport for Business
