dt987
Jul 11, 2017Aspirant
Failover UDP DHCP relay M4300-52G-PoE+
Hi All, I'm currently using UDP DHCP relay on M4300-52G-PoE+ switch to point to a DHCP server in our network per VLAN interfcae, server itself is Windows 2012R2 VM. DHCP works perfectly fine. No...
dt987
Jul 12, 2017Aspirant
Well, that would be true if DHCP servers are not on Windows 2012R2 in DCHP failover cluster:
https://technet.microsoft.com/en-us/library/dn338978(v=ws.11).aspx
DHCP servers will constatnly sync leased IP addresses so there will be no confilct in case of failover.
So the question remains if it's possbile to add two DHCP UDP relay on Netgear VLAN interface
JohnC_V
Jul 12, 2017NETGEAR Employee Retired
- JohnC_VJul 14, 2017NETGEAR Employee Retired
If there still anything else that we can help, feel free to post here on our community! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
