HolmesNetworks
Aug 08, 2024Star
M4300-52G-PoE+ and UWB-XG
Can a M4300-52G-PoE+ Ethernet port power a Unifi BaseStationXG (UWB-XG)? The UWB-XG maximum needed wattage for the UWB-XG is 31w (source: Quick Start Guide). It also requires 802.3bt, but it's the po...
- Aug 09, 2024
We tested it anyhow and it does in fact power the BaseStationXG, but like you also mentioned won't meet the maximum power requirement. We will use the included PoE injector with the XG to compensate. Thank you for the alternate suggestions for powering the switch.
HolmesNetworks
Aug 09, 2024Star
RennaD
Aug 11, 2024NETGEAR Moderator
Hello HolmesNetworks,
Please disregard the M4350-48G4XF(GSM4352) as it only supports PoE+ (802.3at). The other two I mentioned does support PoE++ (802.3bt). Thank schumaku for pointing that out.
You may check data sheet and manuals below:
Page 2: https://www.downloads.netgear.com/files/GDC/M4250/M4250_Datasheet.pdf
Page 2-3: https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
Page 154: https://www.downloads.netgear.com/files/GDC/M4250/M4250_UM_EN.pdf
Page 196: https://www.downloads.netgear.com/files/GDC/M4350/M4350_UM_EN.pdf
We’d greatly appreciate hearing your feedback. If ever your concern has been resolved or answered, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
Have a lovely day,
RennaD
Netgear Team
